New clutch for me : (
Well, the general consensus is that my TO bearing is bad. So wwith 79K miles on it, I am going to replace the clutch and slave as well.
I am:
Resurfacing the flywheel-$36
Need OEM LS6 clutch kit-Where can I buy this and how much?
Need slave-O'riely's has the stock one I think for $77?
Labor $325 for everything
T/O bearing-??
I want it to be OEM spec. Since I dont plan on adding much, if any more hp this will be fine for my needs. Advice/help as to where and what?
I am:
T/O bearing-??
resurfacing is fine with a stock clutch...i had terrible hot spots and they were able to machine it like new again...unless your going with a lighter flywheel, resurface it and save some money for something else...
Originally Posted by Specialized
Shouldnt need to.
How do you need a new clutch already? You just bought your car a couple of months ago.
Idiotic if you ask me. My TO bearing has a noise as well, but I bought a new clutch (RAM HD) to replace the clutch because I fear it slipping with my spray and the new cam that is going in.
Why do a clutch that has absolutely no problems? Do you like wasting money?
Why would you pay to have the tranny removed if it isn't necessary in the first place?? Granted the clutch may not have much left in it, but you don't know that, if it isn't slipping it isn't slipping. Now I don't know how loud your TO bearing is, but I’m sure the majority here on the site have noisy ones as well. If you were upgrading the clutch to something stronger then I’d understand, but keeping it stock and doing it because it’s making a noise seems like some expensive preventative maintenance. Besides get that thing up on jack stands and do it yourself!
