View Poll Results: Should i replace my clutch?
Yes, since you are there
1
33.33%
No, it should be fine
2
66.67%
Voters: 3. You may not vote on this poll
Should I replace the cutch?
Should I replace the cutch? POLL
about 25k ago i put in a textralia OZ700 clutch, flywheel, pp, slave, master w/ drill mod, and pilot bering. The clutch has about 40 passes and 25k miles n it. My car has about 330ish rwhp and has no signs of slipping. the only problem is the T/O bearing is bad.
I just ordered a moser 9inch from exotic peformance and while i was down there i was going to replace the slave and T/O bering. Since im there do you think i should replace my clutch? Can i get some opinions? Thanks in advance!
My TO is making some noise and I have 80K miles on a stock clutch. I am replacing that as well as the slave and TO. I don't think you need to do your clutch yet, measure its thickness and judge based on that.
