machining the flywheel
I have a spec stage 2 clutch and i wanna upgrade it to a stage 3 clutch, the flywheel has two hot spots in it would you reccomend i machine it, by the way I have the spec bilet steel flywheel. IAll help is greatlty appreciated
make sure to get them balanced or you will get a really good vib. around 2200 to 4600 or so RPM. I thought that spl would send the flywheel and ls6 disk and presure late already balanced but they were 43 grams off.
