Shift knob
Shift ****
Ok, my car has a shortned stick and the stock hurst shifter and shift ****. With it being shorter now the stock **** doesn't feel very good to shift with. What would everyone recomend? Right now its between the Black Hurst Classic 6spd and the MBA plain aluminum. Any suggestions?
I've used 4 different *****, and I have the T-Handle on right now. But for what it's worth, if you're using a shortened arm, use a Leather hurst **** or the Hurst Classic, but I think you'd like the leather shifter better.
Originally Posted by YoDa3297
This is what i recommend
Its alittle at first but after a day or two you'll never want a different shifter ****
Between the two ***** you asked about I would probably go with the classic Hurst.
