Down shifting to 2nd
Since I've owned my car (about 2 years) it's always had trouble down shifting to 2nd... It downshifts fine if I blip the gas, or if I'm going fairly slow... however if I try to downshift to 2nd at around 40mph and I am not meeting it with RPMs it makes a strange whirring sound and after a few seconds of applying pressure it will finally slide into 2nd gear. This isn't a big issue because I don't typically downshift this way but it does seem a little strange. Is this at all normal or does anyone have any ideas as to why this is happening? Main reason I'm asking is my warranty expires soon so if it needs any tranny work now is the time. Btw flywheel/clutch/TO bearing were just replaced.
wrencher
Originally Posted by brad8266
Probably worn tranny parts such as syncros.
Dont know you rear gear ratio, but that could be alot of speed to push into 2nd that wont help. It just wears parts.
Originally Posted by 00BlueTA
If still cover under warenty I would take it in and have it fixed, no reason to have it come out of your pocket latter when it is free now. btw it sounds like a sincro to me.
Yeah I'll take it in next week when I'm home. I've just had a lot of warranty claims and they have started to become a pain in the ***, just don't want to have them actually decline a repair. I guess they can't though since they are covered components. Thanks for the help.
Yes a downshift is harder on the blocker ring as it has to speed up the gear,
instead of an upshift, speeding up the gear to come into sync..
As far as getting it repaired under warranty, depends on the relationship with
the dealer..
How many miles on the car?
the dealer..
