ram clutch powergrip set any opinions on this clutch?
my clutch burnt out in my 99 trans am ... i have headers, gmmg exhaust, slp lid and cold air induction kit... with plans on putting more and more on later...
was thinkin about getting the ram clutch powergrip set ...is this a good clutch for the money? or is there better ones for less or around the same price?
http://www.ramclutches.com/zen-cart/...roducts_id=421
and do u think i should replace the flywheel?
thank you in advance...
Originally Posted by brad8266
A lot of people use the RAM clutches and have good stories about them. I would at least have the flywheel resurfaced and be sure to buy a new slave cylinder.
i would NOT however get the stock flywheel resurfaced, unless they can do it with just one pass.
i had an overheated flywheel that i had resurfaced, they had to go over it a few times to get the surface right. it threw the thing out of balance, the motor did not want to rev. i'd just buy a new one from RAM.
just my experience - when you get parts from the same company, they seem to work better together.
stock resurfaced flywheel + spec3 clutch = CRAZY CHATTER AND VIBRATION - spec billet flywheel + spec3 clutch = like butta
Originally Posted by sidewayz28
i got the RAM powergrip HD, RAM steel billet flywheel, adj. master cylinder and slave cylinder going in new friday... im hoping for good results
for now - ls7 and stock master ftw. lol
Its a good idea to at least consider the new flywheel. The Powergrip would be fine for your car, if you plan on much upgrading in the near future go with the HD (and billet flywheel), or look at the Street Dual Super smooth.
here a cheap place to get RAM clutches. RAM powergrip HD for $389.
http://www.neweraperformanceparts.co...57715&PageNo=2
Kinda odd when the own manufacturer is super high. and whats up with the other sponsors price gouging? damn.
If your working on a budget and want a strong clutch, Ram Powergrip HD is the way to go.
It will take anything you can throw at it and beg for more. It's really that tough.
I also got mine thru NewEra.
