Master cylinder help
I'm underneath the dash and the retaining plate after the 13 mm bolts on the cylinder won't budge!
I'm following it up the reinforcement and found no way to "unbolt" the plate from the arm. It seems to be one whole piece it holds the clutch safety switch and some other switch on it too.
This is driving me nuts as my back is in agony trying to figure out how to get past this one little plate.
