Proper way to break in clutch...
What is the proper way to break in a clutch? Does it matter what your pushing or are they all the same? I only got 7,000 miles out of my last clutch. would like the new one to last a little longer. all comments are great...
Russ
Russ
it all depends on the clutch material. If its a metalic disk, like a copper pucked clutch, there is no break-in needed. But if its an organic disk you should contact the manufacturer to see what their recommendations are. Not sure about Carbon or semi-metalic disks...
Very Interesting Concept
Originally Posted by o1m6ss
push the clutch in, push the gas to the floor(and hold), then side step the clutch. repeat this process 5-10 times. good luck
With my luck, I'd have to get a new clutch right away.
