McLeoud Adjustable Master Cylinder
Does anyone have one, or has anyone had one or known anyone to have problems installing one in their car. I just got my tranny back from Six Speed Inc, and bought a McLeoud adj. master cylinder. Having a problem getting the thing to seal right. Seems that it is binding up and leaking fluid. My mechanic filed some of the metal off of the banjo nut and it looks like it should not bind anymore. Again, has anyone had a problem with this, or is my installer doing it wrong?
Thanks
Thanks
Joe said you can't file it without causing it to leak. It should not bind it. It has a crush washer and should have bolted right up. If he filed it or over tightened it that will cause the leak you called me about. I will call him in the am but he didn't tell me he filed it down. I would have told him no to do that.
Amber
Amber
