LS 7 clutch problems post here - LS1TECH
Thread Tools Search this Thread
Old 04-28-2007, 09:00 PM   #1
Default LS 7 clutch problems post here
How many of you have had problems with the new LS7 clutch setup?
My problem- The center hub is loose and allowing the disc to wobble, which is causing vibration and noise when I shift. It has 25K highway miles on it.
It is in a 99 TA with minor bolt ons. This is also, the second disc that has done this. I had a Zo6 setup in it and the disc hub became loose after 20K.
The tranny was gone thru by LS1 Joe at the same time the LS7 clutch was installed. I bought the LS2 flywheel/Ls7 clutch set from Joe.
What might be causing this? Is this just an inferior product? I see great things on here about the LS7 clutches but I never see any issues that people are having other than having to shim them.
Gearhead and proud of it.
gearheadbob is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
