Question on removing transmission
Old 04-29-2007, 03:05 PM
berger21's Avatar
Default Question on removing transmission
I am trying to remove my tranny using the instructions from install university, but I am hung up at one step. Once the 8 15mm bolts holding the tranny to the bell housing are removed, the tranny is supposed to slide back to get to 2 10mm bolts. I can not get it to slide. Is there a trick to sliding it back, or is it supposed to be difficult? Any help is appreciated.
Old 04-29-2007, 04:58 PM
pro2low's Avatar
ive had my trans out a couple times and dont remember any 10mm bolts that you have to side he trans back to get to. try turning it and pulling it back that what i had to do since it hit my trans tunnel......stupid question but you have the shifter off and torque arm, and crossmember?
Old 04-29-2007, 06:01 PM
fuel man's Avatar
Post
Just disconnect the clutch line at the quick-disconnect , the slave will come out with the trans. I'm in the middle of a clutch swap as we speak.
You must tilt the engine back, I did till it bottomed out on the firewall slid it back and turned the trans I think counter-clockwise a little and presto!
I hope this helps
Old 04-29-2007, 07:15 PM
JakeY2KZ's Avatar
Is this the first time the tranny has ever been disconnected from the bell housing? If it is, it'll be a bitch to get it off. A rubber mallet and a flathead screwdriver is all you need and just start
Old 04-30-2007, 09:16 AM
berger21's Avatar
Yes, everthing is disconnected and the shifter is removed.
Old 04-30-2007, 09:18 AM
berger21's Avatar
I hope this helps
Do you have any support under the engine, or is it hanging free from the engine mounts back?
Old 04-30-2007, 09:20 AM
berger21's Avatar
This is the first time out. Where did you place the screw driver?
Old 04-30-2007, 12:46 PM
JakeY2KZ's Avatar
Yea that's your problem, the first time is a bitch to get it disconnected. Just take the flat head and put it anywhere a little gap is between the bell housing and tranny. Make sure the tranny is supported for safety reasons. Once you get the screwdriver in just keep applying pressure and it will jolt loose. There's two stubs that helps guide and keeps it in place on the tranny. That's what it's stuck on. Keep at it, it'll come losse.
When you get to the slave...try not to disconnect the slave line. If you can keep it connected that will save you from not having to bleed the clutch (that's if you don't want to). The 2 10mm bolts are easy to get to once the tranny can slide back.
Old 04-30-2007, 03:39 PM
berger21's Avatar
Thanks, I'll give it a shot.
Old 04-30-2007, 06:26 PM
Mike44138's Avatar
If you look at the side of the bellhousing where it meets the gear box at about 3 o'clock and 9 o'clock there are actually indentations where you can fit a screwdriver or pry bar in. Try and use these because, if you significantly damage the mating surface betwee the gear box and the bellhousing you can mess up the input shaft alignment.
Old 05-02-2007, 07:10 AM
berger21's Avatar
I found the indentations and it popped right out.
Thanks.
Quick Reply: Question on removing transmission
