need a clutch
Old 05-03-2007, 03:29 PM
wvaboy's Avatar
Default need a clutch
long story short version
nick williams put a ls7 in my t/a. i have an exedy twin disc clutch. it's starting to slip. it's not holding in high rpm's in 3rd or 4th. made some calls today, and apparently they were rated at 1000hp fly wheel when i bought the clutch, 1 1/2 to 2 years ago. but now are down around 550rwhp. it was ok with the ls1 set up, but not with the ls7.
seems everyone is going textrilia or spec. is there something else i should be looking into that will hold 600 rwhp? i may put a 100 shot on somewhere down the road so clutch needs to be able to support minimum of 725.
i'm hoping someone from spec. might chime in and pm. me a number i can call and talk with someone tomorrow.
thanks for any advice,
rob
Old 05-03-2007, 03:51 PM
SPEC-01's Avatar
Rob, You are welcome to give me a call at your convenience. I can be reached at 800-828-4379 x.109. I will be more than happy to talk with you about all of the options available for your specifics needs. I look forward to hearing from you. Thanks,
Old 05-04-2007, 09:09 PM
STILL 2 SLOW's Avatar
I would talk to a sponcer to find clutch that will hold that kind of power. Well reliably I mean.
