Clutch master cylinder rod clip?
Im using a "C" clip on mine. Im not sure the techie term... Looks more like a C and an E put together... here is a picture of what I mean.
Seems to work fine. But then again I have a RAM master cylinder with a spherical rod end...so maybe it wouldnt work with a stocker.
Justin
Justin
Originally Posted by LS1-IROC
Thank you for the part number...I have been using a c-clip for awhile and I just don't trust it.
Edit...Just realized your car may have been a 5spd from the factory... If it was, nevermind about the pics.
Justin
After 2000 miles of mine being lined up almost straight, mine started to leak on the inside. Upon taking it out, I found some scoring ont he plunger only on one side. Im not sure if the push rod was pushing it to the side and making friction, or if the constant side pressure wore the seal... not sure...
When I first put it together, this is how bad it was lined up...
Now it looks like this. It was never driven like the above pics. Just like this one...
Im going to adjust it some more with the new master cylinder and try to get her even more straight. I swapped my adjustable rod into the new master cylinder so I can mess with the rod length. We'll see how it goes...
Sorry to hijack your thread, but since its semi-related and you got your part number I figured it would be ok.
Justin
Justin
Yeah...I wish I knew for sure if it was going to be an issue. But since I dont, Im going to try my best to make it line up better.
I found that slotting the holes alittle for the bolts helps. Rotating the body instead of sliding it up and down seems to work good. Since mine was off in a couple directions.
I hate crawling under there too. Such a pain in the butt. I think Im reinstalling it all tomorrow along with my insulation for the clutch line. So Ill let you know and snap some pics of how it lines up afterwards.
J.
J.
Well, I fianlly got a chance to fiddle around with my master cylinder. Glad I did....it works much smoother now and the slight sticking at full travel is gone. I had to slot the holes a bit so I could rotate the cylinder. It didn't take much but it's seems ALOT better now. BTW...the part number listed above worked like a champ and was only $1.55 with tax from the local dealer who ACTAULLY had them in stock. My pics are kinda blurry
This is what it looked like before
And now after rotating it slightly for a better angle.
