ok, bad synchros or do i need a new clutch?
as the title states, im having a problem with it scratching as it goes into 3rd when i shift fast. i plan on replacing the clutch in a few months, and also rebuilding my tranny within the year, but what do you guys think is causing this?
By using the Turkey baster method you never fully remove the older broken down fluid from the lines, Master, and Slave. Thus it is not ideal. I would suggest flushing and refilling (using a vaccuum sorce) and going from there. I hope this helps.
