What is the best way to remove roll pin?
Ok. I got the tranny out. Now I need to remove the extension housing. I believe the isolator cup assembly must come off to do this. There is a roll pin holding this assembley on. Does it need to be drilled out? I can not seem to get it to budge?
Originally Posted by Shawns30thannZ28
yea punch and hammer will do. then just a hammer to go back in. you will have to take it out otherwise the main case will not slide off.
