Do I have everything I need for my Clutch swap?
wrencher
That is pretty much it internal to the bellhousing. make sure you are prepaired w/tools to get the pilot bearing out.
That & a clutch alignment tool.
You can also concider doing the drill mod as well, for good measure.
The drill mod removes a restriction in the line between the slave and master. Its mostly to allow you to shift into 3rd without delay when you're beating on it.
http://www.installuniversity.com/ins...r_cylinder.htm
Only off the wall tools you'll need are the alignment tool, pilot bearing puller (rent it at autozone), long extensions (with wobble heads even better) to get the top bellhousing bolts out. A trans jack would be nice, but if you've got some big friends it's not a requirement.
Awesome... well I work at autozone and My buddy works at a dealership and we get to use their lift and tools after hours. They have all done it in their cars but I was kinda wanting to learn for myself. Just have them hangin aound for when I got a question and to steer me the right way. Also money is tight so is a master cylinder really neccasary? What are some symptoms of a faulty one?
Most the time your master will be fine. The quick check is to disconnect the line from the slave and try and push the master with normal pressure. If the pedal doesn't move it's okay. If it does then you either have a leak, bad seals, or air in it. Don't worry about the master if it's not leaking, you can replace it much easier than the slave. A lot of people get so fed up with clutch and bleeding problems that they apply the shotgun technique and just replace everything.
