t56 problems
Old 05-08-2007, 10:07 AM
khaos288's Avatar
Default t56 problems
so the slave cylinder is going on the t56 and its kinda drivable as in i can get into gear but its rough, is it safe to drive it up to the shop or should i not try it and get it towed?
Old 05-08-2007, 11:57 AM
Mike44138's Avatar
If it's just starting you should be fine to drive it there. Just try and rev match your shifts as much as possible and don't beat on it. If you drive that way long term you'll just end up chewing up synchros.
Quick Reply: t56 problems
