Vibration
Vibration
I have a vibration only when you first start moving .....once the clutch is out all the way in first gear it doesnt do it again......sometime if you let the clutch out right it wont do it ( I am used to a stock mount on a lightly modified z28).....is this just what a poly transmission mount does....? Should I put in oem or leave it alone.....car is not stock (mods are below)
