pedal sticking to floor@ high rpm
I just replaced my entire clutch system even a new t56 I'm using a ram hd clutch. I ve done the drill mod the pedal feels good and stiff whats next?
I have the same issue its driving me nuts, im considering going auto next year. I will have to take mine into a professional. I replaced master, slave, did drill mod, wrapped clutch line, resurfaced my flywheel....and the stupid clutch gets soft and pulls towards floor at the strip. ls7 cltuch setup
CARTEK Racing
Your clutch if overheating the clutch fluid. The clutch must be slipping at high RPM which is where it is most likely to slip. My stock clutch used to do the same thing when I was running it with my old old H/C setup 5 years ago.
My CARTEK clutch never slipped
Moderator
assasinls1, try wrapping your clutch line with heater hose and/or heat reflective material, then flush the system with new fluid and bleed accordingly. Tie the clutch hydraulic line back as far away from the source of heat (headers). That should help. If not, then as WS6TransAm01 mentioned, your clutch is somehow heating up your fluid.
Jason
Jason
