Best clutch fluid?
Old 05-15-2007, 08:50 AM
The SSheriff's Avatar
Default Best clutch fluid?
I was just wondering what everyone was using as far as clutch fluid was concnered, because I can see that it is time to change mine (and also, how often should I change it?)
It hasn't been changed 25,000 miles :-(, and I think that could be the answer to my intermittent hesitation in 1st gear.
Old 05-15-2007, 02:05 PM
TheLS1Kid's Avatar
Valvoline synpower.
It "exceeds" DOT 3 and DOT 4 fluids.
Old 05-15-2007, 06:12 PM
black01_WS6's Avatar
anybody else have any ideas, as I am going to be doing this soon as well.
Old 05-15-2007, 09:22 PM
92slowmaro's Avatar
you guys flush your clutch fluid. ive never heard of such a thing. but dot 3 brake fluid works pretty good.
Old 05-15-2007, 10:29 PM
speed_demon24's Avatar
You do realize that there is a section called "manual transmission" that they put here for these kinds of posts right? And how would "old" clutch fluid cause your car to hesitate? I guess I never heard of "intermittent clutch fluid hesitation"
Old 05-15-2007, 11:12 PM
92slowmaro's Avatar
there is no need for making for of someone for asking a question. and since clutch fluid is brake fluid i can understand the idea of doing a flush on it. becaues the system is not air tight so it could become contaminated after a while. just my thoughts.
Old 05-16-2007, 09:17 AM
well the main question is is there something better than the stock fluid, if not ok. I am putting in a new master and slave, and if one fluid is better than another why would I put in somehting that is not as good.
Never heard of hesitation in 1st either because of fluid.
Old 05-16-2007, 04:43 PM
TheLS1Kid's Avatar
Why does nobody believe me?
Im the only one that made a suggestion in this thread.
black01_WS6, at least use DOT 4 fluid. If you want better go for the Valvoline synpower. The boiling point is higher so there is less of a chance of the fluid burning.
Quick Reply: Best clutch fluid?
