clutch/trannie vibration?
When i am up around 5500-5750rpms the pedal starts to vibrate , its nothing i have ever seen, i have driven my brothers 97 c5 m6 and it doesn't have the vibration at all, what could this be? anything to do with the clutch itself?(doesn't slip) or maybe the mounts are going bad?,
thanks in advance
michael
thanks in advance
michael
wrencher
Holding down the clutch in like ready to side step the pedal at the track is when you feel this?
Or you riding the pedal, I'm not sure I follow your question, just want to be sure.....
no its when the clutch is fully engaged, (havn't been dumping the clutch from 5500 rpms lol,, its just feels like the pedals are vibrating when it gets up to where i should be shifting(i've been shifting before then cause of the vibration) when i'm gettin on the car. its only up around 5500-5750rpms tho nowhere else
wrencher
OK I was just asking cause I do dump the clutch from 5500 & higher lol.
Is it a replacement clutch set?
Was it balanced? Sometimes they are not, depends upon who's set it is.
Did the problem start in conjunction with something else like another mod or part install?
The cars compeletly stock, I'm thinking the clutch is stock,, maybe time fora new clutch or something.. Could it be a trannie mount possibly? Or more than likely my clutch
