6 speed to 6.0L
Old 05-18-2007, 07:58 AM
steve gilmore's Avatar
Default 6 speed to 6.0L
i have a 6 speed tran. out of a 2000 camaro and i'm trying to bolt it to a 2005 6.0L motor out of a 2500 HD truck. What is happening is the input shaft is going through the pilot bearing and bottoming out before the bellhousing is tuoching the motor.( about 1/2 inch)Why is the input shaft to long??? is there a aftermarket bellhousing that would work???
Old 05-19-2007, 12:09 PM
1999ssls1's Avatar
I had the same problem with mine. It is out of a 99-00 not a 05. You have to use a ls1 crank.
Old 05-19-2007, 03:19 PM
Smile
i found someone that can shorten the input shaft on the tran. i do not want to mess with the motor because it only has 1,000 miles on it. THANKS FOR YOUR HELP
Old 05-19-2007, 03:51 PM
1999ssls1's Avatar
K man. Hope it works out.
Old 05-21-2007, 04:00 AM
Top Secret's Avatar
My 6.0 is out of a 2002 Denali. Would I also have to shorten the shaft? Or should it just bolt right up?
Old 05-21-2007, 08:07 AM
1999ssls1's Avatar
It should bolt up. Does the crank stick out about a 1/2" past the rear main cover?
