Is this bad? *pic*
CARTEK Racing
looks like old tranny fluid that made its way up though the grease that is packed into the center of the Pro 5.0 shifter.
It should not have happened because there is usually almost now fluid in the shifter linkage compartment but I would not worry to much about it.
Did you recently fill the trans with fluid? Maybe overfilled?
I have not done anything with the tranny since ive bought it except put the pro 5.0 shifter on.
Mine is similar but nowhere near that bad. How long have you been running the shifter? I've only had mine in since the first week of January. It's not the tranny fluid either because I changed that over to Syncromesh around the same time.
Originally Posted by BlackScreaminMachine
Graphite based grease such as anti seeze has that look.
