Is it possible to use mighty vac to replace clutch fluid
My clutch fluid is all black and burnt, and i was thinking if it is possible to use the mighty vac to replace to clean fluid.......and how do you do?
Clean out the resevoir, then pump the pedal about 10 or so times. It will start mixing in the rest of the system and will darken again. Continue until you get clear fluid. I would be nervous about the miti-vac as it is putting a negative pressure on the seals in the slave, not sure what affect that might have. There is a procedure on CF for the above that was developed by someone called "Ranger".
Link to protocol
Link to protocol
