Drill mod trouble
Old 05-29-2007, 02:39 PM
onecamaro1's Avatar
Default Drill mod trouble
WTF!!!!!!!!!!!!!!!!!!!!!! I was doing the drill mod and the bit broke off inside. i tried everything to get to it. I'm fresh outta options. Any advice before i go buy another master?
Old 05-29-2007, 03:10 PM
Fibbado's Avatar
wait, you were drilling into the master cylinder?
I thought the restriction was in the line coming off of the master cylinder? How the hell did you break a bit?
Old 05-29-2007, 03:59 PM
onecamaro1's Avatar
It is the line.
onecamaro1's Avatar
But nobody sells just the line.
Old 05-29-2007, 05:30 PM
onecamaro1's Avatar
I'm done. it works.
Old 05-29-2007, 08:24 PM
todds69's Avatar
how did you get it out?
Old 05-30-2007, 11:30 AM
onecamaro1's Avatar
I bought a dremel carbide tip and a buch of 1/8 carbide drill bits. Since it broke off all jagged, i ground at the drill bit with the dremel until i could solidly hold it in the center and it not walk off to the sides. Then i started re-drilling and i saw chunks of the drill bit coming out. I kept replacing bits every 30 seconds until it went all the way through and then i flushed the line a LOT. MORAL: When doing the drill mod, use the toughest bit you can find, cheap crap will break off if it catches on anything.
Quick Reply: Drill mod trouble
