LS7 Clutch 26 spline?
Is the LS7 clutch a 26 spline clutch?
Also what flywheel should be used with it on a 02 F-body?
Those who have this clutch what are your opinions on pedal feel, longevity, characteristics, etc.? How does it hold up to a little abuse. I know some of the Z06 guys saying the clutch is very finicky...what is everyone's experience with it on F-bodies?
Thanks so much...tried a search but didn't come up with much.
I just ordered the ls7 clutch package, comes with clutch and flywheel from FredBeans. I like the clutch it has a stock feel. I have a tr230 cam/bolt on's and 150 shot...I can smell i am starting to over-power the clutch every now and then but it seems to be holding up well. If all you are going to run is what you have in your sig list of mods the LS7 clutch would be perfect for you setup...just my opinion. ...BTW it is a 26 spline and will bolt right on..might think about throwing in a bronze pilot bushing and a new slave while you in there...save u time or money in the long run.
I got my LS7 clutch installed in early May and have had no problems with it. Everything bolted right up so the splines were correct. It drives great, grips great and really doesn't feel any different than the LS6 clutch I had in there previously. I did replace all hydraulics (and did the drill mod) and added the bleeder extension. Easiest bleed I have ever done! Good luck with yours.
