6th To 5th
6th To 5th
I ran into a problem yesterday when i tried to downshift from 6th to 5th. It is like running into a wall. I tried several times with no luck. I can can get it to downshift by applying pressure and then reving the motor with the clutch pushed in. All other gears are fine even when shifting 4th-5th or even shifting 5th-6th. Synchro? Sixspeedinc rebuilt my trans and i have since put about 5,000 miles on it with no problems until this little pita.
anyone else have a similar problem before- i just bleed the system with no change. My master cylinder fluid was low and it looks like my slave may be leaking right where the bellhousing bolts to the motor when the little crack is or my rear main is leaking..??
Sounds like a syncro. It's always harder on the syncros to down shift than its to up shift. When up shifting the syncro works sort of like a brake to slow the countershaft down to make a smooth transition but when down shifting the syncro must work very hard to speed the countershaft up.
wrencher
How does the pedal feel? Release low?
You can hurt shift fork pads (if oe plastic) or other hard parts forcing shifts with marginal hydraulics.
I got a new slave coming in so i am going to try that and see if it fixes it. On the way home yesterday it downshifted from 6th-5th about 4 times then it quit again which leaves me to believe the slave is screwed up. It still is throwing me off as to why it is not acting up in any other position...we'll see. I hope this fixes it, SixSpeed inc did my rebuild, joe and amber know what they are doing over there which makes it hard for me to believe my 5-6 syncro is screwed up especially since i am never hard on my trans past 4th.
