Need QUICK input..T56 Tremec BRONZE fork pads, Yes or No
Old 06-05-2007, 08:11 PM
rjw
rjw's Avatar
Location: Tinker till it blows, then back it off a notch, maybe!!
Default Need QUICK input..T56 Tremec BRONZE fork pads, Yes or No
I broke down and decided to have a local shop drop my drivetrain, so that the clutch can be replaced and tranny repaired.
Tranny stays stuck in 4th whenever it wants to, so I have the steel fork, billet dogs, etc.
I have both the plastic and bronze fork pads. A local Tremec dealer suggested that the bronze oned would stiffen things up a bit.
Anyone NOT have good experience uses these?
Thanks
Sorry for the rush, but it has to happen tomorrow
Old 06-05-2007, 08:29 PM
Fire-formula 93's Avatar
I installed them in mine and have no problems. The plastic ones I pulled out had about 20k on them and were fairly worn. The bronze ones will basically last as long as you have the car. Some reported slight noise, something like brake pads on rotors, but I have no noise what so ever.
Old 06-05-2007, 08:31 PM
LS1TECH Sponsor
badpewter-z's Avatar
bronze, firm postive shift every time however if you dont like a notchy firm trans go plastic
Old 06-05-2007, 08:58 PM
wrencher
wrencher's Avatar
I would say yes, I prefer them over plastic every time.
Old 06-05-2007, 09:29 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Go with the bronze pads
Old 06-06-2007, 11:36 PM
10SecDreamer's Avatar
for some reason they dont fit as good as the plastic ones?
maybe i need to take of a little chip from the center of the bronze pad?
Old 06-07-2007, 09:38 AM
onebad82z's Avatar
I would not alter them at all. They don't fit as good, from what I have read researching T56 rebuilding here on the site it is recommended you epoxy them on.
Quick Reply: Need QUICK input..T56 Tremec BRONZE fork pads, Yes or No
