Clutch line Part #
wrencher
Originally Posted by HavATampa
It's not sold seperately if I remember correctly. It only comes with the master cylinder.
Unless you make your own. Only issue with that is you have to access the slave to screw in you line. I want to do that eventually. And I was going to have an extension screwed into the slave, then the custom line screwed into that then up to the master. That way you can still remove the master and all without pulling the trans.
But your best bet is to try to find a used master. Whats wrong with your line that you want to replace it? My old one has a major kink in it or I would just give it to ya.
Justin
Justin
I called and comfirmed this. Can't get the line seperately at the stealership plus I can't get used because I can only work on my car over this weekend. My quick disconnect connector drug on the ground and got eatten up. Can't use it.
Have to get a whole master cylinder. Looked at places like Summit online for other ones besides the dealer and all the pics show no line. I have a corvette master but the line isn't flex plus too short.
I am out of 160 bucks, folks.
