Smoothing out shifts/ Synthetic fluid
I want to make my shifter feel less notchy, and I read on WS6.com that synthetic fluids make shifts much smoother. I believed that guy on that site used Red Line fluids. Does anyone have any before/ after experience with stock fluid to synthetic? Which would you guys recommend? I'm thinking Royal Purple right now, but I'm also considering Red Line, and just about anything else. I want to eliminate or remove the notchy feel. What about shifters themselves? I have a Pro 5.0 short throw shifter. Would the SLP shifter be any better?
Also, any suggestions on differential fluid? I'm trying to make the car as efficient as possible before I start with the bolt ons, so I figure flushing and replacing all of the stock fluids is a good place to start.
Thanks in advance guys
I noticed no real difference in shift notchiness between synthetic and regular. I just use the synthetic for the added protection.
I did this comparison within a span of a day as well as I was using the regular stuff to flush out any metallic debris in the fluid.
Well if we're doing comparisons, in it was stock GM Syncromesh, then off the shelf Mister Transmission ATF, then Mobil 1.
I did the same "flush" with Shell ATF then Amsoil.
The transmission feels the same regardless and I recently had it rebuilt with all the regular upgrades, and due to the bronze fork pads, it got even notchier.
I've come to accept that the T-56 will be no fancy butter transmission, but it will hold a hell of a lot more power.
Originally Posted by BriancWS6
T-56s are notchy when compared to alot of other manual trans vehicles, it's just the way they are.
As far as fluids, I like Pennzoil synchromesh in the trans, and I just use regular Valvoline 80w90 gear oil in the rear.
Kleeborp the Moderator™
Originally Posted by speed_demon24
Where do you get the pennzoil synchromesh at? And to the original poster you have an auburn differential so make sure you use non synthetic in it.
Also, its not reccommended to use Synchromesh in the T56. The transmission is not designed for synchromesh, its designed for ATF. Its stamped right on the side of the case, "ATF only". Amber from T56Rebuilds says they only use ATF in their transmissions, even after a full rebuild. They've found it works best, which makes sense considering the trans was originally designed for that fluid.
Originally Posted by ONEBADASSWS6
You can use Synthetic in the Auburn with no problems. There are so many rumors about Synthetic. I have Mobil 1 75W-90 in my Auburn rear and its been fine, plus you don't need the limited slip additive when using synthetic gear oil.
Question:
First time doing my own T56 Transmission fluid change. How do you refill your transmission?
Originally Posted by JayBirdWs6
Thats what I just put in my rear yesterday Mobil 1 75w90 but I didnt know you didnt need the additive when using syn. Oop's!, I dont think it will hurt anything though.
Question:
It won't hurt anything.
There is a fill plug on the side of the transmission. I believe it is on the drivers side of the trans. Just take it out with a 3/8 drive ratchet, and use a fluid pump to refill it with ATF. You can get one at WalMart for about $7, its just a hand opertated pump with a tube on each side, one is suction one is fill.
Originally Posted by MeentSS02
I've found most of the Auto Zones I've gone to have had the Pennzoil Synchromesh.
