View Poll Results: How to bleed clutch correctly?
1.Push in pedal 2.open bleeder 3.close bleeder 4. release pedal
43
70.49%
1.open bleeder 2.push in pedal 3.close bleeder 4. release pedal
18
29.51%
Voters: 61. You may not vote on this poll
Correct Way to bleed Clutch???
Old 06-25-2007, 11:47 AM
SLOWblackZ's Avatar
Default Correct Way to bleed Clutch???
So I did the drill mod and was bleeding my clutch afterwards. The first method I used after pumping the clutch about 100 times was like doing brakes: push clutch in, open bleeder, close bleeder, release clutch. This did not get any pedal feeling. I then went on to do the other method: open bleeder, push pedal in, close bleeder, release pedal, which got some pressure back to the pedal and I got it back to where it was drivable. Searching the site, I found that most people use the second method, but usually bench bleed the master which I did not do. Is it better to use the first method after the master is semi- bled out? I also purchased a mityvac, but even with this the clutch is still not fully disengaging during mid to high rpm shifts. I am going to do the manual bleed and flush out all the fluid and try mityvacing it again. Any help would be appreciated...
Old 06-25-2007, 08:22 PM
ls1 joe's Avatar
Always push in the pedal first then open the bleeder. If not you can cause air to go into the lines of the slave.
Amber
Old 06-25-2007, 08:24 PM
wrencher
wrencher's Avatar
I even close the bleeder just before the flow stops just to be sure the master doesn't bottom out & 'bounce' in turn sucking air.
Old 06-26-2007, 11:54 AM
brad8266's Avatar
I also close the bleeder before the flow stops.
Old 06-26-2007, 02:50 PM
vettenuts's Avatar
Amber
How do you figure this, opening first will only initiate gravity bleed.
Old 06-26-2007, 07:25 PM
wrencher
wrencher's Avatar
Your right it will start gravity bleeding, but then you have your helper push the pedal down. Then fluid will come out solid stream out the bleeder.
I like to close it before flow stops to keep it from getting air when the master bottoms out.
Old 06-27-2007, 09:22 PM
zman99's Avatar
how do u bench bleed it? i ve tried it like the brakes pump it up then bleed and have nuthing!!!
Old 06-27-2007, 09:33 PM
wrencher
wrencher's Avatar
If you bench bleed a master do it with the line installed. You have to depress the center core of the line where it attaches to the slave.
Then release it before the bottom of the master's stroke.
Repeat until bled.
Old 06-27-2007, 09:35 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I bought a Motive pressure bleeder so I never have to worry about it again. That along with my slave extension is the "right" way to do it for me.
Old 06-27-2007, 10:00 PM
10SecDreamer's Avatar
I used method number 2. Fluid circulates so much faster and only toke me 10 mins to bleed the clutch.
Old 06-28-2007, 01:17 AM
SLOWblackZ's Avatar
I thought it was a vacuum bleeder and as I said in my post I bought a Mityvac... same thing i believe
Old 06-28-2007, 10:25 AM
MeentSS02's Avatar
Nope...two different animals. The Motive piece uses positive pressure, the Mityvac pulls a vacuum. I have both, and the Motive is what I use.
Old 11-15-2007, 04:32 PM
robertbartsch's Avatar
Where do you buy the positve pressure bleeder - the Motive?
Old 11-16-2007, 08:31 PM
MrEddie's Avatar
Yep, the Motive and slave extension will work wonders. If you do a search, there's some info on it. It's been a year since my new master, slave, slave extension, drill mod, Motive power bleeder, and all is still great - can bang third without any notchiness....
Old 11-17-2007, 01:16 AM
Yowzerman's Avatar
Summit Racing carries them.
Tom.
Old 11-20-2007, 03:17 AM
tomz28's Avatar
this is the way to do it just in case go on you
Old 11-20-2007, 03:29 AM
thunderdan74's Avatar
I do #2. I also raise the back of the car higher than the front. The bleed port inside the slave is at the back of the slave. Having the car raised in this manner will help any air rise to the back of the slave instead of the front.
Old 11-23-2007, 11:13 PM
BriancWS6's Avatar
The latter.
Old 11-24-2007, 01:22 AM
TARZAN's Avatar
As has been said.....#2
-Will
Old 01-26-2008, 01:11 AM
zrocket_99's Avatar
Mighty Vac! Auto Zone $30. Takes 5 Minutes.
