How long?
How long?
Ok so long story short, I got oil all over the clutch and its slipping. A lot of it has burned off but it still slips when under a load. I have been driving it real easy but will it eventually grab like it use to? Anything I can do to help it?
Originally Posted by JMBLOWNWS6
Replace your rear main seal and replace the clutch. No other way around it. Sorry!
You've soaked the friction material in your clutch with oil, you need to replace it, you could possibly start a fire lol it gets pretty hot in there Make sure you douse (sp?) everything in brake cleaner before you put it back together.
