t-56 weight?
Old 07-05-2007, 01:23 PM
Dip Stick's Avatar
Default t-56 weight?
Curious how much they weigh so I know if the little 450 lb tranny jack will suffice.
http://www.harborfreight.com/cpi/cta...emnumber=39178
Old 07-05-2007, 01:58 PM
DONAIMIAN's Avatar
You will be fine. Its somewhere betwene 95-105lbs.
Old 07-05-2007, 02:19 PM
Gary Z's Avatar
I've removed and installed my T56 twice with that jack - it works great.
Old 07-05-2007, 02:30 PM
Dip Stick's Avatar
awesome thanks. Though it seems to have some height issues if I use it with a kwiklift. i guess i can order some of those moving dolleys or something to put under it.
Old 07-05-2007, 02:31 PM
gnx7's Avatar
They are 135lbs dry.
Old 07-05-2007, 03:37 PM
ae13291's Avatar
ohh yea when we were dropin my buddies M6 when we pulled it back to get it off the pins the tranny dropped on my friends arm and completly shattered his arm! but he is ok now
Old 07-06-2007, 05:12 PM
convexion's Avatar
Dip Stick, I use a kwiklift as well. What I did was just use an old door I had around, cut it to 3' W x about 4' L and it's 2 1/2" thick. Then I just used the approach ramps that came with the kwiklift to guide the trans jack onto and off of the plank of wood. That gave me enough height to reach the transmission without any difficulty.
Old 07-06-2007, 09:05 PM
DONAIMIAN's Avatar
Damn, didnt feel that heavy when I pulled mine.
Old 07-06-2007, 09:08 PM
MrEddie's Avatar
I have that jack and a kwiklift, and I used some sheets of plywood to raise the jack jack a few inches to that it contacted the tranny. The tranny jack is pretty nice and relatively cheap.
Old 07-07-2007, 01:49 AM
jmdale1984's Avatar
1+ Agreed.
Old 07-07-2007, 11:29 PM
Disturbed Bird's Avatar
be a man and use your muscles you should be able to bench press more than 135 i hope. lol
Old 07-08-2007, 12:27 AM
SScam68's Avatar
YEP!!!
I have this one
http://www.harborfreight.com/cpi/cta...temnumber=3185
It was on sale for $99, couldn't resist. Especially after I almost killed myself
(not really) removing it the last time
I picked up the dolly from Lowes, 900lb capacity and only $20.
You can easily make some spacers to fit between the casters to get the height you need.
I've loaned the jack to 2 friends of mine and they all LOVE it. Makes life SOOOOOO much easier.
I've weighed my T-56 @ 125lbs wet.
Quick Reply: t-56 weight?
