quick stupid question be 4 i buy it!!!
1 Post
hi i am bout to buy a 2001 slave cylinder for my 99, is buying the slave only still gonna be benificial to me? is there any benifits of the 2001 slave over the 99 slave? thanks
Location: Your girl's back door giving her the long stroke while you're at work
This is from the sticky. FWIW I went with a RAM big bore slave and haven't had any problems with it
7. What’s the deal with 01-02 hydraulics? My 98-00 stuff seems to work fine.
If you are going to go through the trouble of dropping the transmission, you might as well change the master and slave cylinder while you are there. While your master & slave may be working okay now, it is a good idea to replace it with the 01-02 hydraulics anyway…because otherwise if your slave fails later on, you will need to take the transmission down again to get to it. The 01-02 has an improved design. Be advised that the line still requires the drill mod!
1 Post
kkk koool thanks alot bro
