Need Help, Hard to shift into reverse after dropping engine/trans
I threw a rod and had to have my engine rebuilt. I just got the car back and for some reason now its extremely hard to shift into Reverse on my M6. Its so stiff it takes two hands to shift it! The only thing I can think of that could cause this is I had poly motor and trans mounts put on while the engine/trans was down. The speed shop that did the work is telling that it is "normal."
Anyone else have this problem or know what I can do to soften the shift into R? All other gears seem completely normal...
Originally Posted by 2001NBMZ28
Any codes? Something easy to check is the ENG SEN fuse, it controls the reverse lockout solenoid - or maybe it's the solenoid itself.
Originally Posted by jmdale1984
They may have forgotten to plug in the reverse lockout solenoid. That, I would think, is the most likely explaination.
Not just check the plug on the solenoid but check to see that they did not swap the skip shift and reverse solenoid plug. They should be color-coded so be sure the plug color matches the solenoid connector color.
