need help with clutch issue!!!
Old 07-14-2007, 11:26 AM
gtkiller97's Avatar
Default need help with clutch issue!!!
Hey guys im not sure where to start but i was driving my car the other day and everything was going fine. All the sudden i went to shift into third and the clutch just felt like it let go completely! No tension when i push on the clutch and it'll go all the way to the floor w/ barely any pressure on the clutch. Im thinkin its gotta be a seal that went, b/c there was no warning all the sudden it just let go. Thanks guys
Old 07-14-2007, 12:54 PM
wrencher
wrencher's Avatar
Leaking fluid anywhere?
Old 07-14-2007, 03:50 PM
ls1aholic's Avatar
definitely check for leaking fluid. also could be the same problem i had. i put a new clutch and flywheel in and the slave went out. just a thought. the pedal was reallly soft before i changed it out.
Old 07-14-2007, 05:00 PM
99FormulaM6's Avatar
check the little clip that holds the master cylinder to the clutch pedal... if that clip comes off, the small rod end of the master can slip off the clutch pedal...
just a thought...
