How much can a stock t56 from a 98-02 trans am handle?
Old 07-15-2007, 06:03 PM
mustangxocutioner's Avatar
Default How much can a stock t56 from a 98-02 trans am handle?
Is there an actual rating from borg warner?
Anybody have any input? I'm planning a buildup which will hopefully end up around 550 hp at the crank so around 490 rwhp. Would that t56 grenade or will it take it?
Old 07-15-2007, 06:32 PM
DVS99TRANS's Avatar
It wouldn't hurt to upgrade it, I think factory specs say they have a 400-450ft/lbs range if I remember correctly. I have been through 2 t-56s and my 2nd is on it's way to Six Speed Inc. right now. I haven't cracked the 340whp range yet and have broken mine, from what I understand it's not the gears but alot of the little stuff (shift forks, keys, etc..) that can't take the power. Although, there are people who put down 500+whp and are absolutely fine and have had no problems.
Old 07-16-2007, 12:59 AM
stainless40cal's Avatar
i know a ton of people who are above 600 rwhp on stock ones and are fine..... no need to upgrade if you can drive the car and not miss gears a lot at that hp level you should be fine
Old 07-16-2007, 02:24 AM
cool... I would mostly be daily driving and probably take it to a left and right racetrack for some time trials every now and then.
Man you sure do get a lot of car for the money with these things.
Old 03-23-2011, 09:03 PM
hotjohnnyls1's Avatar
500rwhp every day!
Old 03-23-2011, 11:28 PM
Sargeant Sh!tbag's Avatar
It is really hit or miss. I was pretty hard on my car at the track and went through 3 of them before finally going built in a 2000z28 I had..
1st failure.. Broken input shaft.. (sheered it off) Sticky tires, hard 4k launch = Boom
2nd failure.. Broken tailshaft.. Trans mounted tourqe arm = Boom
3rd failure.. Broken 3rd gear.. powershift with ~400hp = Boom
4th tranny built in the 2000 and one I have now built = Massive amounts of abuse and still ticking..
Moral: If you are nice to the stock tranny it will last.. Beat on it like it is built.. BOOM
Old 03-23-2011, 11:40 PM
jcoker's Avatar
550 at the rear, stock t-56, and I beat mine like it owes me money.
Just saw how old this thread is.
Old 03-23-2011, 11:42 PM
Timebomb sir.. haha
That is pretty amazing though.
Quick Reply: How much can a stock t56 from a 98-02 trans am handle?
