Need advice - what clutch to get :)
Old 07-17-2007, 12:49 PM
Vetal's Avatar
Default Need advice - what clutch to get :)
So I bought my TA and the clutch is slipping. I have about 340whp, but plan to put some 100 shot. It's daily driven, but I do dragracing a lot. We don't have special tracks here, so I have to slip a clutch a lot to get good start.
So, what inexpensive clutch should I get? Please advise
Old 07-17-2007, 12:51 PM
brad8266's Avatar
LS7 or maybe a full disk spec stage2
Old 07-17-2007, 04:50 PM
Vetal's Avatar
Was thinking about Spec2 also.
Don't I need flywheel as well with LS7 clutch? That won't be inexpensive anymore
Old 07-19-2007, 10:40 AM
Vetal's Avatar
Can SPEC Stage 2-3 be slipped a lot? Please advise
Old 07-21-2007, 05:10 PM
Dillard99's Avatar
Get Mcleod 600 or 800 series clutch disk or if you go Spec get the 2+or 3+
Old 07-21-2007, 06:53 PM
Closed Sponsor Account
ERIK@MASPORT's Avatar
Spec is trouble man....LS7 all the way!
Erik
Old 07-21-2007, 08:00 PM
Vetal's Avatar
From what I read LS7 wouldn't hold 450-500whp...
Old 07-21-2007, 08:21 PM
340 wheel plus 100 shot = 440rwhp (technically, not actually) = not even close to an LS7 clutch's limits...
If there is any doubt, throw an exo skel in there and never look back...it is $$ though..
Erik
Old 07-21-2007, 08:25 PM
Vetal's Avatar
100 shot will not be final, just to start (yes engine is forged)
What is LS7 limit then?
Old 07-22-2007, 12:39 AM
Just do what Young tells you and buy a Text EXO SKEL!
ARGGGGHHHHH
Erik
Old 07-22-2007, 02:49 AM
silverZ98's Avatar
cartek
Old 07-22-2007, 04:31 AM
Vetal's Avatar
I really can't afford $980 or $1250 + shipping + taxes
What I didn't tell you is I'm going to swap in A3 next year because I want to install turbo and I'll be dragracing a lot. So this clutch will not be for 2 or 5 years
So as I understand you strongly recommend against SPEC, and vote for LS7?
Old 07-22-2007, 06:46 AM
studderin's Avatar
I was in the same boat, Ive put alot of clutches in at the shop. We dont use spec anymore. And beem using rams,I liked them. And went with a ram HD for room to grow, we stock them also so it was easy. But see if you can drive a car with one, same pedel as a powergrip BTW.
Old 07-24-2007, 06:56 PM
Vetal's Avatar
I'm leaning more towards SPEC Stage 2+... Mainly because LS7 setup weighs over 65lbs and it's too expensive to ship.
BTW I have SPEC Stage1 now in my Nissan Silvia, and it holds more or less fine, even with all clutch-slipping launches it has to deal with. Perfectly fine in city driving too. But I bought this clutch about 2 years ago... Maybe quality have changed since then?
