pro 5.0 install?
Old 07-20-2007, 11:14 AM
98dropta's Avatar
Default pro 5.0 install?
got mine used so i dont have any instructions.....does the engraving of pro 5.0 go at the top (upside down) or at the bottom?
thanks
nate
Old 07-20-2007, 12:04 PM
ghettocruiser's Avatar
Towards the front. Just match it to how the stock shifter is oriented.
J.
Old 07-20-2007, 12:15 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Did it come with longer than stock bolts? I only ask because that seems to be something that is commonly overlooked. Aftermarket shifters generally have thicker bases on them than the stockers, and if you don't use the longer bolts, you stand a good chance of stripping out the threads in the transmission. Take this advice from someone that has become a seasoned heli-coiler.
Old 07-20-2007, 12:21 PM
GregAbell60143's Avatar
If it was bought new, the Pro-5.0 shifters do come with new bolts
Old 07-20-2007, 12:24 PM
98dropta's Avatar
thanks alot...thats how i had it in but it seems to be hitting my console when i try and put in R(might be my short stick)...........just making sure i didnt put it in wrong
it came with the longer bolts..............
thanks for the help
nate
Old 07-20-2007, 12:28 PM
MeentSS02's Avatar
Yes...but his was used. I was just making sure (because I didn't realize this once upon a time with my Ripper).
Old 07-20-2007, 12:33 PM
98dropta's Avatar
yes mine was used................but he did send me the right bolts for the shifter.........thanks for the heads up
Old 07-20-2007, 12:56 PM
ConfusedGarage's Avatar
thanks for the help
nate
Mine did the same thing. Seems like the Pro 5.0 and short stick make it a few hairs to right, and R kinda rubs. It pissed me off at first, then you forget about it.
Old 07-20-2007, 01:33 PM
The short stick shouldnt have anything to do with hitting the console since it bolts to the driver's side of the shifter. Its the shifter itself that hits the console. If its just a matter of a tiny bit of interference, just take a knife or dremel to the console. That area gets covered by the boot anyway. Or, try to loosen up the bolts for the console alittle shift it over a bit.
Then again, if you are like me and dont use reverse that often, its not a big deal and you'll eventually just ignore it.
Justin
