Best LT1 Clutch
Best LT1 Clutch
I have a 93Z. I was wondering in your guys expeirence what is the best clutch for a decent price. I tried to do a search but it requested a time out. I plan on porting the stock heads, 224/230 510/503 comp cam, headers, exhaust, Keith Black pistons, Scat Rods, stock crank, and all the little stuff along with bolt ons. What clutch you think will be the best?
AVOID Mcleod Clutches. I went through two that lasted about 8 months a peice on a bolt on LT1. After the second one I threw in an O'reillys stock replacement clutch for $200. Three years later and its still holding fine, hmm....
My setup in sig is pretty much same as yours. Mccleod 7500rpm single disc on Ram Al flywheel. Bought the single disc seperate. Then I bought a clutch kit at Autozone and threw away the stock disc. Saved over $100 doing it this way. PP's are the same as stated above and all are LT4 PP's now a days.
