Slack in the shifter?
Old 07-31-2007, 11:47 AM
JCKIRSTINE's Avatar
Default Slack in the shifter?
I just recently developed a problem with my shifter. I just installed an OEM Hurst shifter in my 99 SS. When I put the shifter in gear it engages fine but the shifter will move approximatly 3" backwards and forward while in gear. It wasn't doing this when I installed it. What do you guys think would cause that?
Old 07-31-2007, 02:58 PM
blownws6_nc's Avatar
Is the shifter stick bolts tight? if so it may be the bushing on bottom of the shifter itself, either way simple to fix.
Quick Reply: Slack in the shifter?
