same ol shit clutch on the floor and i'm a newb so help plz
same ol **** clutch on the floor and i'm a newb so help plz
ok got a 99 m6 ls1 and drove fine for 2 days then this morn got up to go to wrk and left the drive way and stoped at a stop sign down the road and hey the clutch woud'nt come back up been read'n for the last hour and bled and pumped the clutch for another hour still get'n dirty fluid but it still is not building any pressure at all it stays at the floor. o and when i pump the clutch i can hear some fluid rushing or something at the clutch petal is this normal or does that mean the slave or whatever that is, is shot. i am very mechanically inclined just dont know anyting about transmissions thnx any help would mean the world
Sorry to hear about your frustrations man. First off, if both your clutch master clylinder (connects to your clutch pedal and is mounted to your firewall) and your slave cylinder (mounted to your transmission and it actuates the pressure plate) were bad, IMO, you'd see some external fluid leaks. I'm taking it that this isn't the case because you didn't mention anything about external leaks. As far as bleeding goes, I'd say that's the majority of your problem. If the problem is resolved after proper bleeding, but yet returns until bleeding again and continues in this cycle, then I'd say you have other issues as stated in the sticky on clutch pedals sticking to the floor(that's my first opinion without knowing what kind of master or slave you have on the car). Its normal to hear some fluid "slushing" sounds from your master cylinder. Although, I did find that my McLeod adjustable master cylinder carries a louder noise when pressing in on the pedal than my stock master cylinder, but it operates perfectly fine. Do you know if your car has the original master and slave or if it has been upgraded (2001-2002 type) and do you know if you have the adjustable master cylinder (can you ask the person that owned the car previously if needed)? The only real way to tell is to remove the access trim plates that are located below the steering wheel and at the base of the dash and take a look at the linkage. Its easy to tell if you have an adjustable rod end on the master cylinder linkage/rod. There are some pictures on InstallUniversity's website if you want a better idea of what to look for. The reason that I'm bringing that up is because depending on how it's adjusted, you may have to remove the retaining clip and disconnect the rod end from the clutch pedal in order to fully compress the master cylinder and allow it to fully extend which, in turn, ensures that you will get all the air out and fresh fluid in. I had the same problem with the master cylinder while trying to manually bleed it on my car. Another thought - I found out a good bit on my car when I looked up the history at the dealership by giving the service department my VIN and they in turn generated a data sheet with noted labor/tasks and parts of past problems on the car that were performed at GM dealerships. In some cases, this may help out to get idea of the cars' past if the original owner brought it in for warranty work or regular repairs.
Anyway, I think you are on the right track with starting on the bleeding process. Just make sure that you are getting full travel in your master cylinder, keep your reservoir full, and check for any leaks. My advice is - when starting with trial and error troubleshooting or process of elimination it is always easiest to start with the simple steps and ideas first because you'd be surprised how it's usually a simple problem to resolve. I hope this helps some.
yea try'd bleed'n all afternoon and thats just not it. i dont think its that for another reason because this just happened all of a sudden. and i can hear the fluid moveing in the master cylinder. i talked to the previous owner and he did have a new one installed about 2 thousand miles ago with a new master cylinder and clutch and all with all 01-02 stuff. i did call autozone and he did buy it not even a month ago. so i called autozone and he got the lifetime warrenty parts so i'm gonna put in a new master cylinder when it comes in on monday.
Just FYI, the slave cylinder can leak and you could possibly never see it under the car. I went through numerous slaves and there was never an external leak, it all leaked into the bellhousing.
yea now i have take'n out my master in process to install the new one but autozone ordered the wrong part so i decided to try and bench bleed my master for the hell of it and i notice when i put fluid into the holder it starts leak'n out of the bottom of the master is this normal or is this obviously the problem. and how do i clean out the braided line after the drill mod and does anyone know wat size drill bit to use?
