Missed 3rd, reverse lights on and stuck shifter...
Old 08-08-2007, 12:30 AM
blk00ss's Avatar
Exclamation Missed 3rd, reverse lights on and stuck shifter...
Ok so i went to jam third gear and automatically new it didnt go into third. So I went to pull the shifter out of 5th and no go. The guy I was racing came up to me and said my reverse lights was on. Also I could rev the motor up like it was in neutral. It is like it got caught between gears. I have heard of this happening with mustangs but not LS1's. So anyways I got the shifter back into norml neutral position after a heated struggle (), and put it into all gears and seemed to feel just fine. So I put it into reverse to make sure it still works, and it does. Go back down the road and shift all through all gears, just fine. No strange catches, or grinding or anything. It seems jsut like it did before the mishap.
So my question is: Did I **** somthing up or am I gravy? BTW I have a recently rebuilt transmission from t56 rebuilds(1500 miles)warranty anyone? LOL
Old 08-08-2007, 12:37 AM
ssman00's Avatar
good luck on that usually if it sticks once that is your warning that problems are on the way or atleast thats how it went with me
Old 08-08-2007, 12:41 AM
blk00ss's Avatar
Yea but it wasnt stuck in any gear. Like it was between 3rd and 5th. I just did a little more searching and came up with a thread about it. Some one said that it might have somthing to di with the way the internals are set up in the t56's? I dont know....just run it till it starts grinding or gets stuck in a gear...
Old 08-08-2007, 08:59 AM
NavyBlue99SS's Avatar
That happened to me once when I had about 40K on the car. I now have 60K and no ill effects and its never happened again.
Old 08-08-2007, 11:57 AM
JakeY2KZ's Avatar
You got stuck in between gates. I did it before and I've read other people do it as well. Just make sure everything is sound before ripping through gears again. I did it about a year ago and still haven't had problems since.
Old 08-08-2007, 12:31 PM
blk00ss's Avatar
Yea I made sure it would go into all gears and everything, then I ripped through them again and all was good! Just a little un-nerving, you know?
Old 08-09-2007, 12:30 AM
Phynix's Avatar
syncro, I did that to mine in 2000, which was when I bought the car, my frined slamed into me while I was downshifting in a corner, split the gears, trans didn't go out though till 05, but that is what caused it
Old 08-09-2007, 12:58 AM
LSGunZ28's Avatar
this has happened to me a lot. but never quite stuck... Ive missed and it went in a no gear, between 3 and 5... and my reverse lighst came on, because it hit the solenoid to activate the reverse lights. But Its never been stuck in there...
u may be fine.
Old 08-09-2007, 02:39 AM
blk00ss's Avatar
Yea I am hoping so. I have a warranty on it, hope this would be covered! Like I said tho, its been doing just fine so far.
Old 08-10-2007, 01:49 AM
LSGunZ28's Avatar
so T-56 rebuilds warranties their transmissions?
I wonder if I should get a rebuild by them, just based on the way I drive
Old 08-10-2007, 12:22 PM
blk00ss's Avatar
Yea, a 1 year or 10K mile warranty.
Quick Reply: Missed 3rd, reverse lights on and stuck shifter...
