Help! I think I may have injured my tranny!!
Hey guys, tonight I wemt for a joy ride with my buddy and we were out on a sticky back road launching the car and logging some datamaster runs...
Well after a couple launches we drove around for a half hour and came back to do a few more runs...
This time my first launch i went to go into second and either missed second or it just wouldn't go into gear because I then slowed down and went to go into third but it wouldnt go, it wouldnt go into any gears while the car was running...
I then turned the car off and it went into every gear just fine... so I turned the car back on in neutral and tried to put it in first but i couldnt even force it to go...
I then decided to put it in first with the car off and then start it, but when i turned it over it started to try to actually pull the car.
I just could not get it in gear any other way so i put it in first and gave it gas while starting it and it still pushed it but i got it started.
once it was started in gear and rolling the issue went away and it went through the gears just fine...
What the heck did I do that it wouldnt go into gear?? Also would you continue driving the car since the issue is gone or do I need to pull this tranny out (which I hate doing lol)?
wrencher
Sounds like you had a clutch non-release issue there.
Could have stuck the disc to the flywheel?
If the pedal felt fine that's the only thing that makes sense on a LT1 pull style clutch set up.
Originally Posted by Zero4488
get a good clutch....
