Connecting Hydraulics w/ trans. mounted
Lame Excuse for a Photog
Is it possible to connect the hydraulic line running from the clutch master cylinder to the trans. without removing the transmission. If so could someone please point me to some directions as to where it connects as it's one of those things i've just never done or seen done before and so im kinda clueless
Thanks,
Rob
Thanks,
Rob
If your talking about just the line, then yes it can be plugged in with the transmission in the car. It connects to the slave on the driver side of the car. You can't miss it.
Now if you are talking about replacing the slave, the trans has to come out to do that.
