View Poll Results: Should i buy the Lightweight Flywheel if im doing the clutch anyway?
Yea, for the $350 its worth the coin
6
54.55%
No
5
45.45%
Voters: 11. You may not vote on this poll
When buying a clutch, Should you buy a Lightweight Flywheel as well?
well my buddy was saying that if your doing your clutch anyways, spend the $350 on a new aluminum flywheel, they are 7-10 pounds lighter and the weight taking right off your crank makes a noticable difference.
figured i would see how other people feel about the same issue.
Internet Mechanic
No, you want weight on the flywheel, otherwise revs drop too quickly, they also raise quicker but unless your Auto-X the car where the revs really never drop as much you want that HD steel flywheel. Also since Aluminum expands and contracts like a mother and prone to warping its best to stick with the heavier steel.
Some people have the miss conception that light is ALWAYS better, the flywheel is one of the cases that disproves the rule. I have driven with a aluminum flywheel on the street, it was god awfully annoying.
Spec sells a decent steel flywheel at a less price, win, win. IMO
