LS7 clutch review
Old 08-20-2007, 10:35 PM
68birdls1's Avatar
Default LS7 clutch review
Mods are in sig, made 373 and 370 at the wheels. And I love this clutch. The relase point has already come up after only 250ish miles. Grabs like hell and the is just amazingly easy to push in. Would def recommend this clutch.. cant beat the price either
Old 08-21-2007, 06:46 PM
ecetim's Avatar
How is the pedal effort compared to stock? I'm fine with my GTO's clutch, but my wife finds it pretty heavy as she has knee problems.
Old 08-21-2007, 08:53 PM
Spyderman25's Avatar
Sounds good, where's a good place to buy both the ls7 clutch and ls2 flywheel?
Old 08-21-2007, 10:20 PM
68birdls1's Avatar
Pedal effort feels just like stock, not a problem at all bud. And the best place to buy them from is one of the sponsors scoggin dicky... $400 for clutch, pressure plate and flywheel!
Old 08-22-2007, 10:31 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Thanks for the referal! Here's a link.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 08-22-2007, 10:39 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Thats a really great price, unless I can beat it local I think ill be going SDPC!
Also, did you use the Shim??
Old 08-22-2007, 12:24 PM
68birdls1's Avatar
No shim, and I don't think you will beable to get it local. The guy who did the work on my car has a great connection at a local dealership and his guy price matched matt, but couldn't believe that he can sell it at that price... My advice, just get it from SDPC, thats what I was gonna do until my bud was able to get it. BTW i've talked to matt a couple of times about other things and he is a great guy to deal with.
Old 08-22-2007, 11:11 PM
SuperSlow02's Avatar
LS7 is the clutch to go with. Only a few problems ive had which are kinda my fault. the Ls7 clutch dosnt seem to like track duty like the LS6 did, you deffinently need to let it cool down a bit. Also one time I downshifted messin around with some audi and spun the hell out of the clutch But I would give the clutch a 10 out of 10, very affordable and will handle any respectable ls1 power
Old 08-22-2007, 11:16 PM
brad8266's Avatar
I was thinking about trying an LS7 when i replace my 3+ soon. I let some girl drive my car one night when i was wasted and she broke my 3+ cause she couldnt drive it right. It still drives but it slips sometimes, so i need a new clutch now.
I just doubt the LS7 will stand up to 700 ft lbs though.
Note to self- Dont take the trans am out when you plan on getting wasted.
Old 08-23-2007, 07:06 AM
68birdls1's Avatar
Dually noted! LOL sorry to hear about that bud, and I am pretty sure that it won't either. You gonna go with a tex then?!?
Old 08-23-2007, 07:24 AM
Internet Mechanic
That must have been a expensive BJ eh?
Old 08-23-2007, 07:47 AM
BIG_MIKE2005's Avatar
With your mods & power level I wouldn't even look at the LS7 clutch. I'd do a McCloud twin disc & be done with it. It's pricey, but it'll take your abuse & ask for more.
On the LS7 clutch mine still lives after a year of beating on it & my H/C install. So I'm also very happy with it. Not to mention the ease of install.
Old 08-23-2007, 08:16 AM
68birdls1's Avatar
Hey bud, how many miles have you put on your setup? How many track passes do you have? Thanks alot
Old 08-23-2007, 09:08 AM
00silverGTP's Avatar
shim or no shim? I am doing the install now, have the shim, but not sure wether to install or not.
Old 08-23-2007, 10:24 AM
NO SHIM.
I have seen this asked WAY too many times on here. I'm not pickin on you specifically so don't take this as a direct insult.
This clutch is a DRIECT BOLT-ON replacement/upgrade. This means no shims & it will work perfectly fine with all stock bolts & hydrolics.
68birdls1: I have had it in for about a year. Several track passes including a couple hot laps. Never had a issue & I have cut a 1.9 60' on it without it slipping. Though it is important to note I only run on street tires b/c of my 10-bolt.
The clutch itself probably has about 15k on it since installed & 5k on the H/C install. Still lights them up @ 40mph in third on a good clutch dump too.
Old 08-23-2007, 11:17 AM
brad8266's Avatar
Yeah it was an expensive night. Oh well, ill likely just get another 3+ since I liked it.
Old 08-23-2007, 12:44 PM
hmmm....ok. valvegod on here is who I bought the clutch off of and he said he installs the shim on every ls7 he does. just getting mixed oppinions here. oh well, I guess its a win win........
Old 08-23-2007, 01:04 PM
68birdls1's Avatar
Every person that I have talked to about the LS7 clutch said not to shim it. It has a self adjusting system, the pedal will come up off of the floor after x-amount of miles. Just do as the instructions say and you will be fine.
Old 08-23-2007, 01:07 PM
Ask Matt @ SDPC. He will also tell you no shim is required also. Maybe that why some of these LS7 installs are gettin messed up? People installin shims on a direct OEM GM replacement where they aren't needed??
Old 08-23-2007, 01:20 PM
1BAD02WS6's Avatar
i beleive the only time you need to put the shim behind the LS7 is if your flywheel has been resurfaced 2 or more times...if you buy the LS7clutchkit and LS2 flywheel no shim should be needed
Quick Reply: LS7 clutch review
