T56 issues
T56 issues
got a 99 Z28.
Thecar was running fine,I then changed over the motor to a low compression forged engine.
After re installing the transmission etc i remember to bleed it. I bled the thing about 5 times and the car will go in 1st and 4th gear only from a start, I have no reveres gear.If i pick up speed like say, 20mph + i can shift through every gear fine. issue seems to be under 10mph or so i have issues shifting. I figured i must have air in the hydraulic system and to do it right, I go out and buy a small mighty vac to bleed the system. After completing that all air bubbles are out, Im stuck with the same issue.. any clue?
Got a ram Hd clutch, new master and slave cylinder just prior to swapping engines and they were in perfect order.
