sticking pedal, could it be the master?
Old 08-26-2007, 10:13 AM
Doski's Avatar
Default sticking pedal, could it be the master?
I have a problem with my pedal sticking to the floor when i go wot, so i was thinking changeing everything.
My friend chnged everything on his car except the master and now he is having the same problem as me.....could it be its just the master that needs to be replaced.
Because my clutch is not slipping or anything, just sticks to the floor at wot.
Old 08-26-2007, 10:18 AM
96ta's Avatar
most people will tell you to look into doing the drill mod i have the same problem havent done anything about it yet except for not go wot as much......
Old 08-26-2007, 10:23 AM
Toes's Avatar
Have you performed the drill mod yet. I had the same problem. cleared it up but eventually went an R&R my master for an adj master. although just bleeding and getting some clean juice in probably helped alot
Old 08-28-2007, 08:15 AM
Doski's Avatar
Ok....But is it possible it could be the master?
Old 08-28-2007, 08:44 AM
2001 SS Cobra Killer's Avatar
Mine is doing the exact same thing. Only does is a WOT. I did the drill mod and it had no effect. I wish I had done a master swap while I had everything a part. It's something that I will be doing soon. Take it from me, save yourself the headache, you can do the drill mod, but since everything will be apart just replace the master.
Good luck! And let me know how things turn out.
Old 08-28-2007, 09:15 AM
Restricted User
2001 Pewter WS6's Avatar
I bought an adjustable Master and it is fine now.
Old 08-28-2007, 09:48 AM
xBROKEx's Avatar
popular theory is you need a new pressure plate/clutch
Old 08-28-2007, 10:13 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Swap the fluid, flush it totally out, its the cheapest and least difficult job.
Old 08-28-2007, 10:15 AM
studderin's Avatar
read the sticky
Old 08-29-2007, 05:38 AM
Doski's Avatar
I have done all that already.....the only thing left is to replace slave, clutch and master.....But since my friend did all that except the master and has the same problem i thought it could be that......
Old 08-29-2007, 06:58 AM
NXPRSS's Avatar
you gotta do the drill mod... my dad had the same problem on his 00' SS.... he did the drill mod, and hasnt had a problem since!
Old 08-29-2007, 08:56 AM
Doski's Avatar
Thanx, But i just said i have done all those things.....
Old 08-29-2007, 09:47 PM
98mysticZ's Avatar
replace the pressure plate.. the rpms counter act the fingers or over come the fingers and cause the pedal to stick... search my name and there is a tsb out by gm on this... its a problem with the ls1/ls6 clutchs factory defect.. mine only did it under WOT and when i shifted after 5500 rpm
Old 08-29-2007, 09:51 PM
98mysticZ's Avatar
found it
https://ls1tech.com/forums/manual-transmission/772561-fixed-sticking-pedal.html
Quick Reply: sticking pedal, could it be the master?
