Problem with LS7 clutch
I put the LS7 kit in from SDPC about a year ago. When I try to shift as fast as possible going through the gears it is very notchy. I can no longer rip it into gear and It seems to be getting worse. I've been driving the SS a lot since my Silverado is in the body shop. I just did the mighty vac to it. That did not help.
Shortly after the install I had to put in a new master cylinder(stock).
Tranny also has been rebuilt.
Drill mod also has been done.
Any ideas anyone? Think it's time for a new master cylinder?
Originally Posted by brad8266
Myabe a new master, its kinda hard to say. Does it have clean fluid in it?
Today starting out in first, I'm starting to get a little chatter. Mind you, there's about 5K on the clutch. I tried running through the gears with the car off. It shifts easily with either the clutch pressed in or left out.
Wrencher: You're right about the problem usually being the hydraulics. In my case it was the hydraulic trouble followed by the shifter feel being notchy. I fixed the hydraulics
with an adjustable master and then traded my pro5.0 for a hurst because it is less notchy. Problem solved.
